John Bond - Group 6 - RB250 Race Scoot - Cool Like 007.....
Posted: Fri Mar 29, 2013 11:28 am
by drunkmunkey6969
RB250 - 36bhp - lovely spread of power for a novice rider to learn the ropes without sh177ing his pants (too much!!) :lol: :lol: :lol: :lol:
They look 'sparse' do cut-downs....but involve a surprising amount of work!
IMG_0066 by drunkmunkey6969, on Flickr
IMG_0068 by drunkmunkey6969, on Flickr
This is what we are given to work with......doesn't look like much to start with! Full length head stock and various mounts/struts need removing.
IMAG1036 by drunkmunkey6969, on Flickr
IMAG1037 by drunkmunkey6969, on Flickr
Grp 6 frame compared to our own stretched/raked sprinter frame
IMAG1070 by drunkmunkey6969, on Flickr
IMAG1072 by drunkmunkey6969, on Flickr
Forks need cutting, sleeving and welding to match the new lower frame.
Left to Right: Standard Length, pair that's been done, pair getting done
IMAG1074 by drunkmunkey6969, on Flickr
Two different 62mm/116mm cranks. The one on the left comes with con-rod machined so that you don't have to scoop out the casings. The one on the right clearly protrudes at the big end so needs casings scooping/machining out. The PM crank on the right also runs a shimmed big end.
IMAG1102 by drunkmunkey6969, on Flickr
Casing with big-end groove machined in
IMAG1103 by drunkmunkey6969, on Flickr
Needs a proper frame/brace for racing seat....don't want it falling off when someone bumps starts you!
IMAG1238 by drunkmunkey6969, on Flickr
Measure up new seat from trimming
IMAG1240 by drunkmunkey6969, on Flickr
Coming together
IMG_0006 by drunkmunkey6969, on Flickr
IMG_0009 by drunkmunkey6969, on Flickr
IMG_0010 by drunkmunkey6969, on Flickr
IMG_0011 by drunkmunkey6969, on Flickr
IMG_0012 by drunkmunkey6969, on Flickr
IMG_0013 by drunkmunkey6969, on Flickr
IMG_0057 by drunkmunkey6969, on Flickr
Lighting coils removed from stator
IMG_0058 by drunkmunkey6969, on Flickr
End result after weeks of work
IMG_0059 by drunkmunkey6969, on Flickr
IMG_0060 by drunkmunkey6969, on Flickr
IMG_0061 by drunkmunkey6969, on Flickr
R1 rear shock, Delly 39mm Racing Carb, QA Throttle, lovely!
IMG_0062 by drunkmunkey6969, on Flickr
IMG_0064 by drunkmunkey6969, on Flickr
Re: John Bond - Group 6 - RB250 Race Scoot - Cool Like 007.
Posted: Fri Mar 29, 2013 3:57 pm
by RICSPEED
seat look far better for a trim ... love that green though :D
Posted: Fri Mar 29, 2013 6:31 pm
by DigDug
One week later..... Cheers Dan & Sean.... 8-)
Posted: Fri Mar 29, 2013 6:50 pm
by mick1
With the forks i notice you cut out a section and weld them back together.......would it not be better to cut to length and re-cut thread at top of forks ?
Posted: Fri Mar 29, 2013 7:24 pm
by sean brady scooters
i suppose that you could try it that way ,maybe its just swings and roundabouts as to which way you prefer ..but bear in mind that you would also need to re cut the groove for locking tab and for the headset clamp bolt .
