dc wiring
Posted: Sun Mar 31, 2013 10:38 am
just gone dc/wassell conversion and was wondering what people have done or used to tidy up the wiring. I have an indian loom with indicators and used the indicator wiring to run some legsheild mounted lights, which have side dip and main and used an indian switch and used the indicator switch to operate the dip and main in theses lights and the ignition to operate the rest as normal with the headlight switch. now, what I did to power this set up was use a big battery and trickle charge off a standard indian electronic and 5 pin regulator, which was alright for short runs and then flat battery. I wired every thing to the battery so in theory I was running full dc. I joined all the wires together with some conector blocks and bridged them with some short loops of wire from one to another. was wondering if there was a better solution to my bodge. also the horn is not as good now and yes its a dc horn (was better than the one on my van), its almost like its an ac on a dc,double checked by going straight to battery. cheers simon
