Page 1 of 2
Wadding and gauze inside a Clubman
Posted: Fri Mar 29, 2013 12:07 am
by storkfoot
I need to cut open an old Clubman, which I need to use again, as I can hear that the baffles have come loose. Whilst I'm in there, I'd like to replace the gauze and wadding to make it quieter.
Has anyone ever done this? Is it possible to buy this stuff? The wadding looks like it's only quite thin
Re: Wadding and gauze inside a Clubman
Posted: Fri Mar 29, 2013 1:15 am
by coaster
I cut open a Royspeed box type exhaust donkeys years ago, they were a standard Innocenti pipe with Roy's own cone welded onto them. I don't remember any 'wadding' inside, It was lined with a coarse mesh but I THINK there was something hard between the mesh and the skin of the silencer. It was only a millimetre or so thick whatever it was. More recently I had an Indian Big Bore which I noticed to be rattling when I removed it. I gave it a good shaking and several pieces of a light coloured material fell out which were about 1 or 2mm thick. It LOOKED a bit like asbestos, I can't be sure, maybe someone else has more knowledge but I would be very careful when cutting, use plenty of water throughout the process
Posted: Fri Mar 29, 2013 4:57 am
by ove
Storkfoot when you cut open the clubman can you take some pictures of the inside and post them on here please?
Cheers ove.
Posted: Fri Mar 29, 2013 8:46 am
by coaster
ove wrote:Storkfoot when you cut open the clubman can you take some pictures of the inside and post them on here please?
Cheers ove.
There's not much in there Ove, just one baffle about a 1/3rd of the way up from the tail pipe which has the inner end of the tail pipe sticking through it. Other than that it's just empty as far as I recall.
Posted: Fri Mar 29, 2013 12:09 pm
by storkfoot
Cheers ove.
It'll be a few weeks before I get round to it. Here's a pic I saved off the internet of a standard box:
Col, the MB Clubman which has just arrived has, what looks like, a thin sheet of the type of wadding you put in endcans, covered by the same sort of gauze they have in other clubmans. Just found this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ink:top:en
Posted: Fri Mar 29, 2013 4:58 pm
by ove
Cheers fella, thanks for posting that.
Ove
Posted: Fri Mar 29, 2013 7:11 pm
by coaster
If you can get the mesh off and back on again then that stuff (maybe a couple of leayers?) should replicate what was originally in there. I hadn't envisioned you cutting it open all the way around, I cut mine straight across just in front of the baffle. The can in your photo is an early one as later ones didn't have the mushroom over the manifold entry. The Lambretta Tunining Manual suggested knocking a big hole in the mushroom with a metal spike.
Posted: Fri Mar 29, 2013 8:11 pm
by tea5ive
here is a thread that I started
http://scooterotica.org/forum/viewtopic ... 8&start=10 , there are some good pics of a twin pipe I cut open. cheers simon
Posted: Fri Mar 29, 2013 10:01 pm
by storkfoot
Thanks, lads. Some good ideas there.
T5, have you finished yours and had it on the road?
Posted: Fri Mar 29, 2013 10:10 pm
by tea5ive
storkfoot wrote:Thanks, lads. Some good ideas there.
its in one piece, just need to finish the cone and u bend might have a go on sunday
