I fitted a pair to my GP while I was giving it a rebuild, I tried to fit the engine back in the frame today and its impossible.
The tubes (that the engine bolt goes through) that are molded into the rubber, stick too far inwards towards each other,so the space between the engine mounts is less than the width of the frame.
The only way i'm going to be able to get the engine in is to take a hacksaw to the engine mount tubes or fit some other engine mounts. When you look at the engine mounts from the outside you can see the tubes in the middle are kind of sunken in.
I am so f@@king tired of paying extra for what should be better quality parts only to find they don't fit
