series 2 key ignition
Posted: Wed Mar 27, 2013 10:52 pm
by wurzel
Am I right in thinking that if I change a series 2 to key ignition I would have to use a TV 175 series 2 type and where would I get one or are there any other types that will fit. Would I also need the TV type light switch.
Cheers Mark
Re: series 2 key ignition
Posted: Thu Mar 28, 2013 3:06 am
by corrado
I would have thought that you could fit a Casa ignition switch. You can't fit the TV light switch and surround to an Li headset, the holes are in different positions. Li lower headset is different to a TV one.
Posted: Thu Mar 28, 2013 6:16 am
by DigDug
As corrado said you only need to use the switch as a kill switch with the green wire and not touch anything else.
Posted: Thu Mar 28, 2013 4:05 pm
by jason frost
Apart from the pink
Sent from my BlackBerry 9300 using Tapatalk
Posted: Thu Mar 28, 2013 6:41 pm
by wurzel
Cheers folks
Posted: Thu Mar 28, 2013 9:09 pm
by DigDug
jason frost wrote:Apart from the pink
It's been a while since I touched the pink....
Posted: Thu Mar 28, 2013 10:29 pm
by squeakmillward
tipping the velvet
only memories
Posted: Thu Mar 28, 2013 11:00 pm
by jason frost
DigDug wrote:jason frost wrote:Apart from the pink
LOL
Posted: Fri Mar 29, 2013 1:36 pm
by wurzel
last time I got me hands on the pink I accidentally touched it with the purple and it blew a fuse
Posted: Fri Mar 29, 2013 11:05 pm
by thebassmasta
just wire it up the same a gp/li/sx use the ignition switch as your main switching, just isolate the wires on the handlebar switch for the lights, wire up the horn and dip switch, simples
