Bought one of these but it has come with the axle already inserted.
http://beedspeed.com/vespa-brake-front- ... 3p4cvluqp2
Anyone got any ideas how to get it off the axle.
Have removed the caliper but can't get the hub off to get at the retaining circlip which I think is holding it on to the axle.
Tried hitting axle with rubber mallet but no joy.
Cheers Bruce
beedspeed disc kit.
GLscoot
- Main scooter: Vespa GS150
Bruce
Remove the cover, split pin and nut. Spray a little wd40 around the axle, turn over and tap with a plastic/rubber mallet. It can take a good few hits. Hit at each of the hub studs from the back. Do not use a metal hammer, the hub is made from an alloy and very brittle.
