S6 KTM 400 UPDATE
Posted: Fri Mar 22, 2013 8:37 pm
by frank sanderson
Re: S6 KTM 400 UPDATE
Posted: Fri Mar 22, 2013 10:22 pm
by drunkmunkey6969
Lovely...
Posted: Sat Mar 23, 2013 8:15 am
by DigDug
Great engineering there Frank.
Posted: Sat Mar 23, 2013 9:57 am
by coaster
Got to agree with DigDug, The attention to detail is impressing me already
Posted: Sat Mar 23, 2013 10:24 am
by gavi4t
great work frank ,how are you mounting the sprocket on the back wheel? if you are thinking of using the three studs and solid mounting it its not strong enough, as ive found with my gas gas engined 4stroke ,theres alot more torque in these engines as oppose to something like an lc ,i solid mounted mine and ripped the sprocket off the 3 studs within 3miles of roads use ,ive made a cush drive system and works a treat ,im not trying to teach you how to suck eggs frank just speaking from experence and may save you from destroying a wheel or worse ....
Posted: Sun Mar 24, 2013 12:37 am
by frank sanderson
Thanks for your advice but I beg to differ done loads of scoots with this hub have never had a problem have a look on website
http://www.lambrettainnovation.co.uk
Every S6 on website (20 ish motorcycle engined conversions ) uses the same hub as fitted to this scoot never had a problem even with the 500 cc scoots and the Hauseberg 400 four stroke . Did you build this scoot originaly? as I remember did you or its original purchaser not have problems with your original back wheel and approach me for advice, With respect to your speaking from experience how many motorcycle engined scooters have you actualy built from scratch yourself
I think the issues you had in the past with your rear wheel as discused previously with me either by you or a previous owner lies with its original design and builder . never fitted a cush drive totaly unescercary never will.
Posted: Sun Mar 24, 2013 6:46 am
by Richjak
Frank is a engineering artist - if i lived in the UK i would be selling my old granny for one of these
Posted: Mon Mar 25, 2013 7:34 pm
by frank sanderson
