Front tyre rubbing on forks
Posted: Fri Mar 22, 2013 4:36 pm
by Herman
Just changed the S83's to Conti Twist race tyres on my T5. I guess that the Twists are slightly wider as the front rubs on the inner side of the forks. One solution would be to fit wavy washers to the hub studs to move the wheel over a couple of millimetres. That's all it would take to avoid the tyre rubbing.
Anyone know if that would cause any handling issues or if that solution should be avoided ?
Re: Front tyre rubbing on forks
Posted: Fri Mar 22, 2013 6:04 pm
by GLscoot
There's something not right here, it is possible to do what your thinking, but this means the wheel is not sitting on the hub properly. If it is rubbing against the forks it must be hitting the shock as well. Your idea will work but when your tyre gets hotter it will expand even more and the washer on the hub may not be enough.
Have you spun the wheel to see if there are any issues, have you tried another wheel to see if it does the same. I feel there is something else wrong.
Posted: Sat Mar 23, 2013 6:18 pm
by Richjak
Check that the rims arent twisted and are running true.
Posted: Sat Mar 23, 2013 7:36 pm
by Herman
Cheers for the advice. As soon as the temp gets above freezing, I'll get into the garage, have a closer look and maybe change the rim
