Series 2 engine mounts.
Posted: Thu Mar 21, 2013 10:04 pm
by Ihateyoubutler
Rebuilding a pretty standard series 2 motor and need new engine mounts. Is there a real difference between series 2 and series 3 mounts with a standard motor? Obviously would need another bolt but I'm trying to keep as orig as poss.
Thanks.
Re: Series 2 engine mounts.
Posted: Fri Mar 22, 2013 12:19 am
by Donnie
is it 125 or 150cc on the top end?
Posted: Fri Mar 22, 2013 10:08 am
by Ihateyoubutler
Probably going to be a casa 185.
Posted: Fri Mar 22, 2013 3:12 pm
by bristolmod
standard short mounts= more rigid engine but possible increase in vibrations.
Longer mounts= more engine movement but less vibration.
Generally a trade off between slightly better handling with the engine mounted more rigidly, and a decrease in transmitted vibes but more movement in the engine unit
Posted: Fri Mar 22, 2013 7:52 pm
by bigmuff
What you need is short mounts and 60mm cranks. Got them in 232 Rapido and 193 sr reedvalve engines. Invest in shares in Loctite ;)
Posted: Fri Mar 22, 2013 7:54 pm
by bigmuff
But they dont collapse, which is a winner in my book.
