slight chip on ts1
lammy57
Hi got a slight chip on the ceramic at the exhaust port about a 1mm by 1mm top of the port would you still run it ?
lammy57
Anyone?
its certainly not good.........but would be very costly to rectify.........replating etc plus time off the road ........just when you dont need that..........
so ,perhaps this may be worth a try.........
could you maybe just extend the port chamfer and so polish it out..........
or also raise ex port by 1mm and re chamfer............
lammy57
Thanks thats what i was thinking I will give it a try
Special X
Do what Sean says. I've got chips out of a couple of muggys like that and one has since done another 30K miles since the repair.
