Scootrs Inboard Disc Brake for drum links????
Posted: Sat Mar 16, 2013 5:55 pm
by shimflips
Thinking about getting a Scootrs inboard disc brake for drum links for my silver special. (can't afford to buy new forks/links to fit standard inboard disc).
Has anybody bought or used one, and do you rate it?
cheers
Re: Scootrs Inboard Disc Brake for drum links????
Posted: Sat Mar 16, 2013 6:13 pm
by Andy Pickering
Haven't used one but have a mate that might be selling one! Fitted it then removed it, preferred the outboard look.
Posted: Sat Mar 16, 2013 11:53 pm
by Bombay Mix Pilot
Hi, I got one of the drum link inboard disc brake units, it works well enough looks as good as an Innocenti original ( castings are as good as the originals ). I have had a warped disc problem but this was probably down to a badly adjusted hydraulic conversion. Make sure you buy wisely and change the pads for quality European ones. All in all a good way to get the original look with drum links, not too pricey either. Hope this helps a little.
Andy
Posted: Sun Mar 17, 2013 10:10 pm
by shimflips
cheers lads, much appreciated.
Posted: Mon Mar 18, 2013 1:27 pm
by byron
I have fitted them, as said, nice castings and went in ok
