silencer re-packing
Posted: Sat Mar 16, 2013 3:40 pm
by philtrate
Hi I want to re-pack my silencer (jl3 newish type) my question is which is the best end to drill the rivets out.
Thanks in advance.
Phil.
Re: silencer re-packing
Posted: Sat Mar 16, 2013 4:31 pm
by rosscla
On mine I started on the end nearest the exhaust which turned out to be the wrong end, as there's a thick alloy plate that end and nowhere for the drilled rivets to pop out to.
Having done that I'd start at the tail end.
Refitting the binding bands and working the riverter is also a three hand job.
Posted: Sat Mar 16, 2013 5:47 pm
by coaster
I found it best to use the blanket type rather than the loose fill. find a length of plastic water pipe that just slips over the inner perforated pipe. It's then just a matter of wrapping it round the plastic pipe, securing with some masking tape and sliding it in and then removing the plastic pipe.
Posted: Sat Mar 16, 2013 7:45 pm
by DigDug
The perforated tube was all coked up on mine which is why it wasn't silencing anymore.
I cleaned it up and just cut off the coked up matting and reused what was left.
Posted: Sat Mar 16, 2013 11:19 pm
by coaster
DigDug wrote:The perforated tube was all coked up on mine which is why it wasn't silencing anymore.
It only cost me about a tenner for enogh to do two ;)
