Lambretta advance and retard
Bren
Main scooter: Lambretta S-Type 225
Any one have ideas why an Augusto and an M-tech would not retard fully?
Have tried both on my ts1 with different stators and CDI's and they both will not fully retard. For example the M-tech set at 19 degrees BTDC will only retard to 17/16 degrees on its full retard setting.
I have also tried different flywheels :?:
Aren't you supposed to set the M Tech at 25 degrees and then choose the switch position to suit?
http://www.lambrettaspares.com/info/fit ... s+184.html
fishi
you have tried this, works perfecly:
http://www.lambretta-teile.de/CDI-Zuend ... etta-Vespa
Minority
Main scooter: Li230 S3
Bren wrote:Any one have ideas why an Augusto and an M-tech would not retard fully?
That's really interesting. I have an Mtech unit that I think is doing exactly the same!
I fitted it after a rebuild and seemed to be getting minimal retardation even on the maximum setting. As I was running in, I set it to a conservative initial advance and was going to revisit the ignition timing scenario with a few more miles on the clock.
I must admit I haven't asked Martin at Chiselspeed about it which I should have maybe initially, my bad! Maybe both you and I should drop him a line.
My setup is basically a SIL 12v electronic ignition which has given me no problems.
giankx
My mtech did the same too, only retarded from 23 to 17 in the fully retard position.
I initially tought it was due to a bad earth contact, but the unit didn't worked well even on other earth points.
Now i've bought another unit with 2 earth wires. Hope it works!
I have a bgm stator with a Beedspeed midweight flywheel and blue Ducati CDI.
Bren
I made sure earth is good to frame and engine. I wondered if it could be the loom earthing out or the ignition switch however this wouldn't explain the consistent movement. It just will not retard past 3 or 4 degrees. Augusto was the same so I am guessing its something on the bike!!
jason frost
Have you run it with the green from the loom unplugged from the coil ?
Bren
Jason, Yes we did that when fitting it so that's the ignition eliminated!
giankx
Which stators, flywheel and CDI did you tried with?
Bren
New BGM stator and a new sil one form Scooter restorations. Two different Ducati CDI's, An elmec flywheel and my original Ducati electronic flywheel. Mixed and matched for my other bike..
