Exhaust Port (classic + race rapido)
Posted: Tue Mar 12, 2013 7:26 pm
by DaveTomo
Just thought I'd update the thread (seems to have gone with the change over to new server) about exhaust port size.Originally posted about a rapido cylinder and my concerns about the exhaust port,one I know is a Classic and the other I told was a classic.Anyway spoke to Ben at AFR this evening during there "idiot hour" (between 5 & 6) and turns out that the other one I've bought is a race rapido.Classic is 37mm from the top of the barrel to the top of the exhaust port ,race rapido is 34mm from the top of the barrel to the exhaust port.The set up I've got 30mm delly open mouthed and a 48 mm clubman will work,but would improve the low down with a reed manifold and an expansion,but it will work as I'm going to be running it.Anyway just thought I'd close off the thread that isn't here and thank the lads for there in put :D
So here you go below a classic rapido
and below a race rapido
Re: Exhaust Port (classic + race rapido)
Posted: Thu Mar 14, 2013 8:42 pm
by Jazzy
Are they both 66mm bore :?:
Posted: Thu Mar 14, 2013 8:50 pm
by DaveTomo
No,had the classic taken out to 225 last March and the what I know to be race just taken out to 225.Both with 1.5mm off the base.
Posted: Fri Mar 15, 2013 10:35 pm
by corrado
I think the classic comes as std with a mahle piston and the race with an asso piston with trimmed skirt. As per Scott or Ben AFR.
Posted: Sat Mar 16, 2013 12:46 am
by rosscla
I'll add back the pic of my tweaked classic
Posted: Sat Mar 16, 2013 12:49 am
by rosscla
I just noticed what somebody mentioned on the older lost post about the differences ...possibly the race is one of the miscast ones MB mentions
Check the difference between the 'long' stud casting
