Monza reed options
Posted: Sun Mar 03, 2013 4:08 pm
by Boreham
Could anyone please advise the various setups possible when replacing the std monza reed block/inlet, the std one has the recessed block but assume you can use an aftermarket reed block if you change the inlet (LTH or similiar)
Any advice appreciated.
Re: Monza reed options
Posted: Sun Mar 03, 2013 8:13 pm
by Darrell Taylor
are you looking to replace because yours is broke? or want better panel clearance or performance improvement?
Posted: Sun Mar 03, 2013 9:07 pm
by Boreham
Hi, it is a performance upgrade
Posted: Mon Mar 04, 2013 1:08 pm
by corrado
You can change the manifold but you'll need to do some measuring of reeds because I believe the std Monza reed is narrower so using an RD etc reed may need some work.
Posted: Mon Mar 04, 2013 1:51 pm
by Darrell Taylor
thats right the reed box needs porting out to accept the larger reed assembly
