Page 1 of 2
Fitting A 12 Litre Tank
Posted: Sun Mar 03, 2013 10:28 am
by soulsurfer
Just dry building, and find the 12 litre tank so tight to the toolbox that, when the time comes, I stand no chance of fitting this without damaging paint. I'd prefer to fit rubbers on the seam but it looks like I barely stand a chance if getting the strap on without scraping off a layer of paint.
Any tips on how you fitted yours?
Thanks
Re: Fitting A 12 Litre Tank
Posted: Sun Mar 03, 2013 12:42 pm
by flameboy
have you tried no bottom rubbers to see if its any better ??
if it is better the thin them out
Posted: Sun Mar 03, 2013 2:51 pm
by soulsurfer
The rubbers as fitted make no difference to the front & back clearance where the seam touches.
Has anyone else had this problem?
Posted: Sun Mar 03, 2013 3:23 pm
by lockman69
With my 12/13 L tank with double carb cutouts from buzzslomoto I have a gap approximatly 20mm between the tank and toolbox... But getting the straps on without scratching the paint was a bit of an issue, with my ape like approach.
Posted: Sun Mar 03, 2013 4:41 pm
by Muppet
try a couple of different tool boxes some mite sit shorter than others
Posted: Sun Mar 03, 2013 7:08 pm
by ktmh5
That tank definitely looks much bigger than mine Mike, where's it from?
Rich'
Posted: Sun Mar 03, 2013 7:18 pm
by soulsurfer
ktmh5 wrote:That tank definitely looks much bigger than mine Mike, where's it from?
Rich'
I believe it's from SSC Rich.
Posted: Sun Mar 03, 2013 11:17 pm
by boonyed
I had one of these and couldn't even get it in the frame. Ended up sending it back and bought a Buzzsolomoto one. That was still tight, but I managed to squeeze it in.
Posted: Mon Mar 04, 2013 12:30 pm
by Doom Patrol
Just a thought. Why don't you buy a couple of these and make your own? Should be doable for someone with a bit of welding skill.
http://www.scooterrestorations.com/lamb ... k-kit-sil/
Posted: Mon Mar 04, 2013 2:46 pm
by gaz_powell
i fitted a Stainless SSC (TS1 cut out) one to an indian GP it required all the rubbers to be reduced slightly but once done there was a gap between toolbox - i managed to fit it without removing the toolbox
have never fitted one to a S2
