Dreaded Lambretta SIP speedo
Posted: Sat Mar 02, 2013 5:48 pm
by sheffieldvisitor
having read many threads about SIP speedos i seem to have a problem that has not been covered (or what i can see), now a bit of history - fitted the speedo a couple of months ago, sometimes worked, sometimes didn't, so today rewired it all (12AC) all seems to be good apart from the speed (MPH) not working when on the road, weird thing when pushed backwards it seem to work??? (yeah only found this out when backing in to the garage) have not touched the speedo cable since the original fitting and worked off and on then !!!!
ladies and gents give me some help before it goes on FleeBay.............
Re: Dreaded Lambretta SIP speedo
Posted: Sat Mar 02, 2013 7:30 pm
by wack 63
Check the speedo drive in the hub and cable first.
Posted: Sat Mar 02, 2013 9:19 pm
by sheffieldvisitor
Many thanks gents, this should have been my first port of call really, bad day, dodgy lamy electrics and 6 year old daughter "helping" me all afternoon....
Thanks again - hopefully be sorted tomorrow........
Posted: Sat Mar 02, 2013 9:49 pm
by simonwwfc
Mines started playing up started going off and on whilst riding
Posted: Sat Mar 02, 2013 10:16 pm
by sheffieldvisitor
By no means a expert but "R" type plug but also a cap seem to have made things a lot better, in the end i got AC power from the back end rather than the headset, just seemed to be getting interferance from anything and everything in the headset.... so after a fiddle with the speedo cable tomorrow all "should" be good.... (said this last time :flaming: )
Posted: Sat Mar 02, 2013 10:29 pm
by simonwwfc
Poss my issue as did ave r spark plug in but removed it so gonna try it tomorrow
