Page 1 of 2
clutch breather
Posted: Thu Feb 28, 2013 1:55 pm
by soulboy
will blocking it off cause any damage sick off it keep leaking oil onto the drum and there bang on 2.50 mil in it
Re: clutch breather
Posted: Thu Feb 28, 2013 2:21 pm
by cit205
The gearbox will pressurise , does it leak more when on a sidestand,is it a modified clutch housing letting the oil chuck up from the clutch straight at the hole?
You could knock something up that moves the breather away from that area, say a pneumatic airpipe fitting into the breather thread and some airpipe that comes over towards the flywheel side ,or at least to a higher point.
Re: clutch breather
Posted: Thu Feb 28, 2013 3:10 pm
by soulboy
cheers for that its all started since i fitted a cosa clutch
Re: clutch breather
Posted: Thu Feb 28, 2013 3:57 pm
by cit205
I had a T5 motor that would do it but only on sidestand and especially if revved, that's got a cosa clutch but i think the cover is standard T5.
It's probably something daft like the where the oil flings up from those clutches just happens to be in the right place to get quite a lot up the hole . It was obviously not the gearbox pressurising from the main seal failing as it would not do it when the bike stood level and it was running fine .
Re: clutch breather
Posted: Thu Feb 28, 2013 4:56 pm
by soulboy
THATS it ...its on the side stand only does when the engine is not runnin
Re: clutch breather
Posted: Fri Mar 01, 2013 1:11 am
by paul d
I thought I had a clutch breather problem on my own T5 a while back . Changed the oil seal on the clutch actuating arm , changed seal on the cover , changed cover and in the end plastered the clutch cover in liquid gasket stuff ! Still no joy and oil on the tyre and backplate . It turned out that the gasket under the carb had failed and started to weep oil out over the cover . Is there a chance that your carb is slightly loose or that the carb gasket has failed ?
Re: clutch breather
Posted: Sun Mar 03, 2013 1:21 pm
by soulboy
its definatly coming out the breather ive sat there with my mag light and watched it all seems ok now though
Re: clutch breather
Posted: Mon Mar 04, 2013 5:47 pm
by soulboy
still doingit realy startin to p155 me off ...any more ideas what about replacing with a new breather
Re: clutch breather
Posted: Mon Mar 04, 2013 11:18 pm
by OzOAP
I fit a breather pipe. Loop up to carb and back down again.
Re: clutch breather
Posted: Tue Mar 05, 2013 10:19 am
by soulboy
THANKS OZ :fb:
