35/35 instead of 25/25
Posted: Thu Apr 30, 2009 12:00 pm
by Bilko
Was given a Halogen 12V 35/35 bulb.
Will it cause anyprobs as it's not 25/25?
Re: 35/35 instead of 25/25
Posted: Thu Apr 30, 2009 12:19 pm
by shocky
not really it might be a little dimmer at tickover
Posted: Thu Apr 30, 2009 12:28 pm
by Bilko
Thank you. :bald:
Posted: Thu Apr 30, 2009 1:03 pm
by coaster
I think all the 12 halogens are 35/35watt, well mine was. As Torchy says, the headlamp may be a bit dimmer on tickover, also it will go VERY dim when you hit the brake pedal :roll:
Does the lamp have a cup under the dip filament? A lot of these halogens don't have the cup and as a result there is no diference between main and dip :shock:
Posted: Thu Apr 30, 2009 1:45 pm
by Bilko
coaster wrote:Does the lamp have a cup under the dip filament? A lot of these halogens don't have the cup and as a result there is no diference between main and dip :shock:
Noticed that when putting it on! :o
Posted: Thu Apr 30, 2009 5:35 pm
by coaster
You can always use the rear brake to dip/dim the headlamp ;) ;)
