Speedo strip - odometer not working
Posted: Wed Feb 20, 2013 9:45 am
by Jxmiddle
The odometer on my SX hasn't worked since I got it and I want to have a go at fixing it before the weather gets improves and I have better things to do in the evening.... :D
Any advice? Any common issues that anyone has found that stop odometers working?
John
Re: Speedo strip - odometer not working
Posted: Wed Feb 20, 2013 4:34 pm
by Daggs
Oh Yes! particularly with Indian remades. With the mechanism out of the casing, you will see a vertical drive that turns the tenths wheel. It's usually this failing to mesh at one end or even both ends. A bit of bending sometimes cures it!
Posted: Wed Feb 20, 2013 8:53 pm
by Jxmiddle
Thanks Daggs, let's hope its that easy. I have visions of loads of little cogs running in different directions cos I was all thumbs!
John
Posted: Fri Mar 01, 2013 11:00 am
by Jxmiddle
So I stripped it down, the vertical drive seemed a bit loose but it looked to me like the horizontal one behind it that disappears off into the internals was the problem. So I had it apart and cleaned it all up. Reassembly was tricky as there seemed to be a lot of play between the drives but I think I've done it. Biggest problem was lining up the numbers, end one of the left is still out of sync. Any suggestions on that?
Now all I need to do is try it on the road and see if it works.
Posted: Sun Mar 03, 2013 12:47 pm
by Jxmiddle
Bo***cks, doesn't work. The 1/10 mile counter is moving and the mile counter moved a little way yhn stopped. And now all the numbers are out of alignment. Start again........
