Page 1 of 2
Varitronic, Using DC Option?
Posted: Fri Feb 15, 2013 10:21 pm
by soulsurfer
I'm looking to use the DC output on Varitronic to trickle charge a 5Ah battery to run gauges, LED rear/brake light & horn, basically everything but the headlamp. I'd also like to be able to switch on the DC feed with position 2 of the ignition switch. Can anyone provide advise, or even better a wiring diagram to achieve this?
Many thanks
Re: Varitronic, Using DC Option?
Posted: Sat Feb 16, 2013 9:57 pm
by wack 63
As far as I know it can't be done,I even opened up a switch to see. Several of the terminals overlap meaning that DC and AC mix.I had to run a seperate switch to power the digi speedo.Was there some talk regarding the Scoot RS switch being able to run both?
Posted: Sat Feb 16, 2013 11:31 pm
by soulsurfer
wack 63 wrote:Was there some talk regarding the Scoot RS switch being able to run both?
Yeah, that rings a bell with me too :-?
Posted: Sun Feb 17, 2013 6:44 pm
by Grumpy225
It can be done but not through the switch. Youd have to wire the headlamp to always on from the AC feed (AC feed to orange from the high/low switch). From there you'd keep the rest of the wiring going through your ignition switch. Not a perfect solution but it would work if you don't mind having your headlight on all the time.
Posted: Sun Feb 17, 2013 7:50 pm
by soulsurfer
Grumpy225 wrote:It can be done but not through the switch. Youd have to wire the headlamp to always on from the AC feed (AC feed to orange from the high/low switch). From there you'd keep the rest of the wiring going through your ignition switch. Not a perfect solution but it would work if you don't mind having your headlight on all the time.
I always ride with lights on, so not a problem.
Just trying to get my head around this, I assume I run the battery +ve to ignition switch live at position 2 giving rear/brake, horn & gauges? This way I'd have AC headlamp on at 1 with the blank gauges being the memory trigger to switch to position 2, DC for the rear and brake lights?
Posted: Sun Feb 17, 2013 8:23 pm
by joespeed
why run the rear light on the battery? the ign sw. crosses over and is likely that you will as wack says have ac and dc together will be worth checking this out,if however you trickle charge the battery and run horn and brake light ,gauges etc then you can hide an isolator sw. in the toolbox.
Posted: Sun Feb 17, 2013 8:47 pm
by soulsurfer
Exploring any options for this Joe, thanks ;-) TBH I'd prefer it if the Varitronic was full DC but that's not looking likely at the moment :(
Posted: Sun Feb 17, 2013 10:09 pm
by jason frost
What about an Li switch for the AC lights and the ignition switch for the DC
Posted: Mon Feb 18, 2013 8:32 pm
by firekdp
soulsurfer wrote:I'm looking to use the DC output on Varitronic to trickle charge a 5Ah battery to run gauges, LED rear/brake light & horn, basically everything but the headlamp. I'd also like to be able to switch on the DC feed with position 2 of the ignition switch. Can anyone provide advise, or even better a wiring diagram to achieve this?
Many thanks
An Indian ignition switch was designed to do exactly what you require.
Posted: Mon Feb 18, 2013 8:43 pm
by soulsurfer
Hi Kev, This one? http://www.scooterrestorations.com/lamb ... dc-indian/
Could you explain how to connect for what I need?
Thanks
