MEC crank question?
Posted: Thu Feb 14, 2013 7:08 pm
by servetakid
I think i read some where on here only certain MEC cranks need piston shims fitting, can some one tell me which do and dont?
Cheers,
Re: MEC crank question?
Posted: Thu Feb 14, 2013 8:04 pm
by Speed Demon
If it has shims at the big end then it doesn't need any at the piston.
Posted: Thu Feb 14, 2013 11:21 pm
by servetakid
Ok cheers sticky, I need the piston shims.
Posted: Fri Feb 15, 2013 9:35 am
by Speed Demon
If I were you I'd spend whatever it costs and put in a better crank instead. I don't know what the budget MEC race crank costs now (about £120 last time I looked) but if you sell what you have it shouldn't be a massive extra investment to get a race crank, but the better big end bearing and no need to use piston shims will be worth the extra, even in a stock motor. I might even have a race crank to flog if you want one.
Posted: Fri Feb 15, 2013 7:19 pm
by Jazzy
Sticky , if you were to re rod a crank, what big end bearing would you recomend
Posted: Fri Feb 15, 2013 8:25 pm
by Speed Demon
I'd let Harry Barlow (Pro Porting) do it :)
Harry uses Japanese silver-caged bearings but obviously which one depends on the pin and rod you are using.
