Which Clutch
Posted: Tue Feb 12, 2013 11:58 pm
by fsmlittler
I'm looking to upgrade the clutch on my Mugello 186. I don't want a heavy lever and don't want to spend a fortune.
All recommendations based in actual experience really appreciated.
Re: Which Clutch
Posted: Wed Feb 13, 2013 12:53 am
by Muttley McLadd
What's the rest of the gearbox?
I'd recommend a four plate with good plates and big springs. That's what my GT runs, and it's fine.
Re: Which Clutch
Posted: Wed Feb 13, 2013 7:14 am
by DigDug
As Mutley said - you could probably manage without the stronger springs with a decent set of plates.
Re: Which Clutch
Posted: Wed Feb 13, 2013 11:42 am
by Donnie
fsmlittler wrote:I'm looking to upgrade the clutch on my Mugello 186.
Why?
Re: Which Clutch
Posted: Thu Feb 14, 2013 12:27 am
by fsmlittler
Running Indian gp150 gearing so 4th is bit tall. Current clutch is starting to slip and hasn't been changed for god knows how long but thousands of miles.
Re: Which Clutch
Posted: Fri Feb 15, 2013 7:28 pm
by Donnie
So if it's been good so far and now starting to slip I assume you've adjusted the clutch cable already and it's still slipping?
If so and the plates do need changing then I'd just replace like for like if its done good service thus far personally. Im running a muggy 186 too and have a standard surflex set up with vespa springs over the normal lammy ones. Been good for years so far.
