Engine studs
Posted: Tue Apr 28, 2009 10:52 pm
by sydduckett
Does anyone know where i can get single engine studs for my series 3, one has sheared off and dont want to pay for the full set if i can help it.
Ta
Sef
Re: Engine studs
Posted: Tue Apr 28, 2009 11:50 pm
by leigh
Which stud are you after
Leigh
think i have a couple of the small chaincase ones in me garage doin feckall.
Re: Engine studs
Posted: Wed Apr 29, 2009 9:31 am
by sydduckett
Leigh,
need the one bottom right, second one in. Need to get it sorted as its holding the build up.
Cheers
Sef
Re: Engine studs
Posted: Wed Apr 29, 2009 9:49 am
by leigh
PM me your address and will send to you not sure if the right one but worth a try.
Leigh
Re: Engine studs
Posted: Wed Apr 29, 2009 6:31 pm
by dirtyhandslopez
Go to a hardware shop and get a long 6mm bolt and cut it to size. Or buy a lentgh of 6mm threaded rod and cut as many as you want.
Re: Engine studs
Posted: Wed Apr 29, 2009 6:53 pm
by shocky
dirtyhandslopez wrote:Go to a hardware shop and get a long 6mm bolt and cut it to size. Or buy a lentgh of 6mm threaded rod and cut as many as you want.
as above make sure you clean the threads out and use a flat bottom tap make the studs approx 5mm longer and use a 6mm nylok full nut and flat washer
Re: Engine studs
Posted: Wed Apr 29, 2009 8:17 pm
by byron
shocky wrote:... clean the threads out and use a flat bottom tap ...
or if you haven't got a tap, cut some grooves [to collect any debris] lengthways on a 6mm bolt and wind this in. this is kinder on the alloy thread as well, they can only take so many retappings. [
tip from Angry Bloke]
Re: Engine studs
Posted: Wed Apr 29, 2009 10:56 pm
by sydduckett
Lads, the only tap iv ever used is either in the sink or behind the bar...
So i think ill give that a swerve...The other issue is that the engines being rebuilt oil and all so i want to try and keep it as easy as possible.
sef
