Page 1 of 3
is there any reason why......
Posted: Wed Feb 06, 2013 10:21 pm
by tea5ive
please remove from your heads the convetional position of exhaust and carb position before answering this question. is there any reason why i cant rotate a cylinder and piston round through 180 deg and the motor not work ?. this is a serious queston and would help with my latest and most rediculous cylinder conversion to date. cheers simon
Re: is there any reason why......
Posted: Wed Feb 06, 2013 10:48 pm
by RICSPEED
well in theory yes it would work .. but ..the studs would not line up (unless you weld and move)also the transfers would not line up
Posted: Wed Feb 06, 2013 10:54 pm
by tea5ive
RICSPEED wrote:well in theory yes it would work .. but ..the studs would not line up (unless you weld and move)also the transfers would not line up
ric, i should have added, just the up and down movement of piston, thrust affects ect.. stud and tranfers wont be an issue with this one 8-) . and cheers simon
Posted: Wed Feb 06, 2013 11:20 pm
by Ian Hepworth
tea5ive wrote:please remove from your heads the convetional position of exhaust and carb position before answering this question. is there any reason why i cant rotate a cylinder and piston round through 180 deg and the motor not work ?. this is a serious queston and would help with my latest and most rediculous cylinder conversion to date. cheers simon
I seem to remember some of the smallframe Vespa kits work like that.
I also remember reading about a Brit scooter that used a generic villiers type engine but it had the cylinder rotated to fit.
Posted: Thu Feb 07, 2013 4:52 pm
by RICSPEED
as long as the piston is rotated accordingly .. yes it will .. not sure id want a carb at the bottom though
Posted: Thu Feb 07, 2013 8:00 pm
by tea5ive
read the first post again ;) , after a dry build this aft and a bit of trimming off the inlet i can get the cylinder on without having to rotate the top end through 180deg. all will be revealed shortly :lol:
Posted: Thu Feb 07, 2013 8:06 pm
by sean brady scooters
i,m fascinated :)
Posted: Thu Feb 07, 2013 8:25 pm
by rondon
in for the unveiling
Posted: Thu Feb 07, 2013 8:47 pm
by tea5ive
Posted: Thu Feb 07, 2013 9:43 pm
by wacky
More more more! What are you up too?
