oil pissin out of over flow
soulboy
i thought it was the clutch cover seal but have replaced it .. but still happening . i maneged to start the bike with the wheel and brake parts all off ,and oil is p1551ing otta the top overflow on the clutch cover BUT ive level filled the oil as it should be :cry: :( :wtf:
soullad
main crank seal has gone, clutch side, thats my guess.
soulboy
i left it ticking over and its stopped .gonna let it cool and see how much is in it ..as for oil goin the engine would be all ove the place ...it falls on to tick over straight away and revs nice and chrisp.........just took filler nut off and quit a bit of oil came out . fuk up on my end me thinks :oops: :oops: :oops:
chrisM
Main scooter: Vespa GS 200
You're supposed to fill only 250 ml, that's NOT a lot of oil!
To be sure I would drain the engine and refill, with a measure ;) ...
soulboy
cheers chris ..and no your right 250 mil aint a lot is it
GLscoot
Main scooter: Vespa GS150
might be less than 250ml, there is generally about 50ml still sitting in there. Syringe is the best way to fill engine oil.
    Users browsing this forum: Amazon [Bot] and 2 guests
