185cc/64mm piston choice
Posted: Mon Feb 04, 2013 10:39 pm
by tea5ive
i have an indian ally 185cc kit and the piston that came with the kit seems rather heavy compered to the piston i had in a genuine sr 185 kit. what are my options as sr are out of sr pistons at 64mm, i dont fancy topping and tailing the cylinder to suit a suzi piston either as the cylinder has been nicely tuned . crank is a standard 58/107 . cheers simon
Re: 185cc/64mm piston choice
Posted: Mon Feb 04, 2013 10:53 pm
by corrado
You could re-rod the crank to TV length and use a Mitaka piston.
Grampian in Liverpool or Harry Barlow could do both for you.
Posted: Mon Feb 04, 2013 11:15 pm
by corrado
Also I think I've got a couple of 64mm Deanspeed pistons that I got from WCLC about 3 years ago. Well I have got them, it's finding them that's the problem. £50 inc P&P.
http://www.socalsp.com/index.php?_a=vie ... roductId=6
Posted: Mon Feb 04, 2013 11:31 pm
by Yanker
corrado wrote:Also I think I've got a couple of 64mm Deanspeed pistons that I got from WCLC about 3 years ago. Well I have got them, it's finding them that's the problem. £50 inc P&P.
Bargain!
If Mr. Corrado cannot find them in his treasure trove, then there is always the Mugello piston: but expect to pay way more.
Posted: Tue Feb 05, 2013 10:39 am
by Stokie
I believe Corrado's 1st suggestion would utilise the Mitaka Suzuki TS185ER piston.
You could also speak to MB about one of their forged Race Tour pistons which would probably avoid the need to change the rod.
They used to have them in 64mm although I think the new batch may start at 65mm and will probably cost a little more than £50.
If you were looking at fitting a reed too then I think the GT kits use a Yamaha 350 YPVS piston which could be an option.
Posted: Wed Feb 06, 2013 11:17 am
by bigmuff
Stokie wrote:I believe Corrado's 1st suggestion would utilise the Mitaka Suzuki TS185ER piston.
You still need to top and tail barrel with RD350 piston. About 3mm, or use a 110 Rod. I topped and tailed an SR barrel, used a homemade reedvalve manifold and get @18bhp. This is with some nice porting by Pro Design in Littlehampton.
Posted: Wed Feb 06, 2013 12:50 pm
by corrado
I found a NOS Deanspeed piston if anyone is interested.
Got a new one at £50 all in and a NOS one at £60 all in. :frog:
Posted: Thu Feb 07, 2013 12:02 am
by corrado
Sorry, there's only one and it's £50. How long do I have to own it for before I can class it as NOS?
Posted: Thu Feb 07, 2013 12:05 am
by Yanker
Another 2 minutes?
