Page 1 of 2
Broken casing!!! Help.
Posted: Mon Feb 04, 2013 7:56 pm
by dopeshots
Hi all, have just stripped my crank to do the bearings and found this........
Is it important...... And does it need to be fixed?
It's a small piece of the case where the crank webs sit.
Re: Broken casing!!! Help.
Posted: Mon Feb 04, 2013 7:59 pm
by dopeshots
A better photo showing where the small bit should go
Posted: Mon Feb 04, 2013 8:27 pm
by LI150
Im sure I have read on here some were about removing these bits of casing to detrimentle effect
Posted: Mon Feb 04, 2013 8:32 pm
by Dell Oughta
I've been running a scoot for about 3 1/5 years, done just short of 9k miles (wish it was more :( ), with the following mods to my casing (its something was shown by Dan on here many moons ago) scoot runs Ok, I'd just tidy the damage up and refit cylinder :)
Mike
Posted: Mon Feb 04, 2013 8:34 pm
by tea5ive
what mike said, a picture paints a thousand words. a what happend with the varitronic issue ?
Posted: Mon Feb 04, 2013 8:49 pm
by dopeshots
Still working on the same issue.... Bearings r shot on both sides of the casing and causing movement. I/We think that is causing the misfiring on the ignition.
Posted: Mon Feb 04, 2013 9:09 pm
by LI150
LI150 wrote:Im sure I have read on here some were about removing these bits of casing to detrimentle effect
Ment to no detrimentle effect . ;)
Posted: Tue Feb 05, 2013 12:58 am
by wrekkah
Dell Oughta wrote:I've been running a scoot for about 3 1/5 years, done just short of 9k miles (wish it was more :( ), with the following mods to my casing (its something was shown by Dan on here many moons ago) scoot runs Ok, I'd just tidy the damage up and refit cylinder :)
Mike
I don't mean to nit pick but it looks like in this photo the drive side seal is in backwards.
Posted: Tue Feb 05, 2013 6:51 am
by dopeshots
Cheers fellas, I'm gonna clean the casing up and put it back together.
Russ :fb:
Posted: Tue Feb 05, 2013 7:02 pm
by Dell Oughta
wrekkah wrote: I don't mean to nit pick but it looks like in this photo the drive side seal is in backwards.
No its not (i've been through this already)...Its just the angle of the pic ;)
Mike
