Crankshaft/Mag housing rubbing
Posted: Sat Feb 02, 2013 9:56 am
by bazabod_downunder
Just started my engine rebuild on my gp150 casing, new mag housing (other was routed) new bearings, seals & fitting a Meceur crank, only part not replaced is the drive side oil seal plate, everything has gone together fine until final tightening of the mag housing, crank won't spin, slacken of the nuts & is fine......... doubling up on the mag gasket may give me more clearance. Only other thing I can think of is the drive side oil seal plate screws need a tweak, but they were torqued to spec & don't want to strip the threads....advice?
Baz
Re: Crankshaft/Mag housing rubbing
Posted: Sat Feb 02, 2013 9:59 am
by Toddy
Did thedrive side oil seal go in ok with the MEC crank there were some issues with early MEC cranks having a high/sharp step on the drive side of the crank
Posted: Sat Feb 02, 2013 10:22 am
Toddy wrote:Did thedrive side oil seal go in ok with the MEC crank there were some issues with early MEC cranks having a high/sharp step on the drive side of the crank
Seemed to, this crank was bought fairly recently......going to put the old routed mag on tomorrow to see if it's a difference in the housing as a quick measure seems to indicate that the new one has more height :/ if that's the case, I really am stumped as what to do
Baz
Posted: Sat Feb 02, 2013 1:32 pm
by coaster
I had exactly the same problem on my engine build yesterday. Indian Li 150 case, new mag flange, new steel seal retaining plate, all new seals and bearings and a Mec Eur crank. All turning fine until 3 mag flange nuts tightened. Thge crank was fully home so I was a bit stumped as I'd never come across this before
Then I remembered seeing different thickness gaskets being offered somewhere, had a rumage through the odd gaskets I had laying around form previous builds and found one that was a bit thicker. Puyt that on and problem sorted. I think it might have been MB Developments where I saw the different thickness gaskets but 2 thin ones will probably be fine, plenty of grease on the gasket and around the boss of the flange. Don't worry too much if the crank is a bit stiff to turn (so long as it isn't scraping) as the seals will be a bit 'grippy' until its bedded in.
Posted: Sat Feb 02, 2013 8:22 pm
Thanks for the reply...was thinking along these lines myself & have ordered two new gaskets to give it a bit extra clearance.
Baz
coaster wrote:I had exactly the same problem on my engine build yesterday. Indian Li 150 case, new mag flange, new steel seal retaining plate, all new seals and bearings and a Mec Eur crank. All turning fine until 3 mag flange nuts tightened. Thge crank was fully home so I was a bit stumped as I'd never come across this before
Posted: Sat Feb 02, 2013 10:14 pm
by wack 63
I'm not a big fan of two gaskets as they can fail,far better to use the thick 1mm MB ones or machine a mm off the mag face.
Posted: Sun Feb 03, 2013 8:20 am
Point taken...thanks for the advice....have ordered a gasket set from MB .5/1.0/1.5 plus new drive side plate, screws & seal
Baz
wack 63 wrote:I'm not a big fan of two gaskets as they can fail,far better to use the thick 1mm MB ones or machine a mm off the mag face.
