holed piston/seizure
Posted: Tue Apr 28, 2009 11:11 am
now i know the obvious but im a bit stuck on this one
engine spec
r.s stage 4 200
rs clubman
std delly 22 with a 118 main jet and std airbox
timing at 18 degrees
my friends bike has holed a piston once
ive rebuilt it with a new piston profiled to ralphs orig spec,now after doing quit a few miles he,s nipped it up,its running but lost power so ive had the top end off and its got the usual signs,but its starting to hole the piston again,i did suggest going to an indian main jet of 123...but he said it ran very lumpy with this fitted
im going to rebuild the bike again but obviously without adjustments its going to happen again
i hate std carbs.....any suggestions on wot to adjust
engine spec
r.s stage 4 200
rs clubman
