Vega legshilds
Posted: Fri Feb 01, 2013 2:05 am
by Rothbard
I'm attempting to make a set of Vega style legshields and need to know what's the typical way these thing get attached onto the fork tube. I've seen pictures of the carbon fiber ones that don't seem to have any bolts or straps up at the top of them . Are they just so stiff that they stay in place at the top once they are bolted to the floor struts?
Re: Vega legshilds
Posted: Fri Feb 01, 2013 8:57 pm
by tony172
mate i dont know the answer to your question, but that looks f****n cool
Re: Vega legshilds
Posted: Fri Feb 01, 2013 9:21 pm
by drunkmunkey6969
Rothbard wrote:I'm attempting to make a set of Vega style legshields and need to know what's the typical way these thing get attached onto the fork tube. I've seen pictures of the carbon fiber ones that don't seem to have any bolts or straps up at the top of them . Are they just so stiff that they stay in place at the top once they are bolted to the floor struts?
No...they have to be bolted on at the headstock. Metal vega leggies have a bracket, but fibreglass and carbon one dont....you have to fab something.
Re: Vega legshilds
by RobD
Mine have a c shaped bracket welded to the inside of the legshields and a horizontal tube welded to the front of the head tube about 6 inches down from the top. The legs of the bracket are the same width apart as the length of the tube (+ a couple of mil) and then a long bolt goes through the bracket and tube holding them on.
Re: Vega legshilds
Posted: Fri Feb 01, 2013 11:37 pm
by wack 63
This is how I did mine ,the bracket is on the Vega shields and then I welded a threaded tube to the frame
Re: Vega legshilds
Posted: Sat Feb 02, 2013 6:35 am
by Rothbard
Thanks for the info.
Re: Vega legshilds
Posted: Sat Feb 02, 2013 1:45 pm
by RICSPEED
wack 63 wrote:
like the damper
mine are the fibre ones and bolt straight to a plate at top of headstock ..
one question though .. why make the leggies ??
Re: Vega legshilds
Posted: Sat Feb 02, 2013 4:54 pm
by sean brady scooters
RICSPEED wrote:wack 63 wrote:
like the damper
also the frame loop and side panels ?
