T5 Polini carb
Posted: Thu Jan 31, 2013 1:40 pm
by mann
Hi I have T5 that i have just fitted a Polini kit 24/24G Cosa clutch & a sito exhaust. How should I set the carb up it has a 120 main jet at the moment. I use it daily for work 30 miles a day on quite roads and and i use it for touring. :!:
Re: T5 Polini carb
Posted: Sat Feb 09, 2013 10:30 pm
by goldeneye
mann wrote:Hi I have T5 that i have just fitted a Polini kit 24/24G Cosa clutch & a sito exhaust. How should I set the carb up it has a 120 main jet at the moment. I use it daily for work 30 miles a day on quite roads and and i use it for touring. :!:
i would up gear it. 22 tooth clutch cog, and go with a 125 main. run it in carefully. have you altered the cylinder head to match the 152 kit? if not, you should . good kits when set up right.
