Drive Side Oil Seal Failure?
Posted: Mon Apr 27, 2009 10:45 pm
Before I take my Lambretta engine apart would some of you kind souls just confirm my suspicions that the drive side oil seal is failing/has failed:-
On an 80 mile round trip about 500mls of gear oil was lost.
There is no sign of gear oil residue in the crank area or inside the piston.
The B8ES plug has a medium brown colour.
Smoke was observed coming from the exhaust during strong acceleration only.
The scoot starts well from cold and hot.
There is no appreciable decline in performance.
There is no oil in the rear hub.
The breather is clear.
It is an Indian engine and I suspect that although the seal may not have blown the retaining plate is alloy and has warped a little.
