Page 1 of 4
Big jigsaw ( moving thread to here ).. 62 li series 3
Posted: Mon Jan 21, 2013 10:55 pm
by Junglemod
Hi
Rather than keep the pics going on show us you scoots , thought I'd better out it in here as its going to end up a resto .
Stripped out headset for cleaning and a little love discovered the old switch housing unit had been butchered by a Previous owner no little screw locating holes left so went to evil bay and bought a replacement one in its plain state , spent a bit of time and polished it to match the opposite side I'd done previously .shiny pic below
Also stripped out fork springs and linkage for new parts and decided to add a set of fork dampers , a little searching on the net came up with the relevant position so dressed primed forks measured and welded into position
Ready for paint now next week .
Re: Big jigsaw ( moving thread to here ).. 62 li series 3
Posted: Mon Jan 28, 2013 8:23 am
by Toddy
Nice work keep posting
Posted: Mon Jan 28, 2013 1:51 pm
by Stokie
I think you've got your fork links in the wrong way
you're welcome
Posted: Mon Jan 28, 2013 5:06 pm
by Doom Patrol
Junglemod wrote:
Junglemod, I don't know how to tell you this but that switch housing is knackered. The hole for the pivot is elongated. You might be able to save it by using an oversize pin. Or possibly get it welded up and drilled out.
Posted: Sat Feb 02, 2013 10:15 am
by Junglemod
Hi
Cheers for that , had not spotted the hole ,will have a look too see if its a trick on the camera flash , can't remember it being oval.
Not sure what you mean in the second pic .
Posted: Sat Feb 02, 2013 12:38 pm
by bristolmod
I'm local (Bradley Stoke) if you need any help
Posted: Sat Feb 02, 2013 12:58 pm
by Junglemod
bristolmod wrote:I'm local (Bradley Stoke) if you need any help
Hi chris
Thanks for that mate , I'm only in pill / Easton gordano been a while since I stripped it all down so might need a little promoting in the right direction sometimes .
Cheers Steve
Posted: Sat Feb 02, 2013 1:54 pm
by Doom Patrol
Good luck with it. Don't forget it's Worcester Parts Fair tomorrow as well if you're interested.
Posted: Sat Feb 02, 2013 1:58 pm
by Junglemod
Doom Patrol wrote:Good luck with it. Don't forget it's Worcester Parts Fair tomorrow as well if you're interested.
Hi chris
Yes mate thanks did see the add in scootering , unfortunately I'm also doing a refurb on my karmann ghia cabrio at the same time as the li , and I've removed all the front beam at present for a narrowed one trying to get that done for end of march too !!!
Cheers for the info though
Steve
Posted: Sat Feb 02, 2013 7:15 pm
by Junglemod
Stokie wrote:I think you've got your fork links in the wrong way
you're welcome
Hi mate
Looks like they are installed but I've only tied them onto damper lugs with a bit of welding wire so they don't get lost before it all goes to paint , think its also angle I've taken the pic at.
Cheers for the nudge though ill be needing some info as I go along ..
Steve
