Jetting Advice
Posted: Mon Jan 21, 2013 9:01 pm
by des
I have fitted a 256mm PHBH 4 stroke carb which has been converted to 2 stroke to a 200 stage 4 engine.
The jetting is currently 128 main jet, AV266 atomiser, needle X2 and sterter jet 55
The engine will only start if i cover the carb mouth with my hand and with the choke out and it will only keep running with the choke out it revs cleanly with the choke out, put the choke in and it dies.
Any advice on jetting a 26mm to suit a 200cc stage 4.
Re: Jetting Advice
Posted: Fri Jan 25, 2013 3:24 pm
by des
Anybody any ideas, why does it tick over smoothly with the choke out and die with it in, whatr do i need to change, up my main jet, atomiser ?
Re: Jetting Advice
Posted: Fri Jan 25, 2013 4:11 pm
by goldeneye
ya must have big hands. :shock:
Re: Jetting Advice
Posted: Fri Jan 25, 2013 4:34 pm
by Muppet
was only one hand; must be HUMONGOUSLYLRGELYMASSIVEIMUSTO
Re: Jetting Advice
Posted: Fri Jan 25, 2013 6:43 pm
by Daggs
The only jet size you haven't mentioned is the Pilot, and that i suspect is where your problem lies.
Re: Jetting Advice
Posted: Sat Jan 26, 2013 9:40 am
by des
Pilot jet is 55 or as i called it a starter jet in my first post
Re: Jetting Advice
Posted: Sat Jan 26, 2013 11:58 am
by col68
Have you tryed a x7 needle ? I have a 30mm phbh on my stage 4 200cc 53 idle, av 266, x7 clip on second clip down from top, 128 main with a ramair filter. A little rich at that but running in still. hope this helps . col
Re: Jetting Advice
Posted: Sat Jan 26, 2013 12:08 pm
by Daggs
des wrote:Pilot jet is 55 or as i called it a starter jet in my first post
In that case, what size Choke jet are you using? I would expect a 70.
Re: Jetting Advice
Posted: Sat Jan 26, 2013 8:18 pm
by nelson pk
What your describing sounds like it's running very weak and with your settings it shouldn't be so i would first check that your mixture screw isn't wound right in and then clean out the pilot circuit with compressed air.
If that doesn't work i would say you may have a nasty air leak.
