Exhaust gasket sealer?
Posted: Mon Jan 21, 2013 2:40 pm
by ArmandTanzarian
Do people use sealer on the joint between downpipe and cylinder or does it get too hot?
Re: Exhaust gasket sealer?
Posted: Mon Jan 21, 2013 3:03 pm
by bristolmod
never use a sealant- relied on the copper gasket and properly tightened nuts
Posted: Mon Jan 21, 2013 3:29 pm
by Donnie
I've always used a heat resistant silicone sealant with copper gasket so a bit belt and braces. Don't need to use a lot, just a smear on each side.
Never had a gasket go since using it.
Also, I always recheck the tightness of the nuts after taking it for it's first run due to expansion / heating / cooling cycle of the cylinder, studs, nuts and gasket.
Posted: Mon Jan 21, 2013 7:46 pm
by byron
Donnie wrote:I've always used a heat resistant silicone sealant with copper gasket so a bit belt and braces. Don't need to use a lot, just a smear on each side.
^all whs
Posted: Mon Jan 21, 2013 8:13 pm
by nelson pk
byron wrote:Donnie wrote:I've always used a heat resistant silicone sealant with copper gasket so a bit belt and braces. Don't need to use a lot, just a smear on each side.
^all whs
+1
Why bother going belt and braces with the head and base and inlet and then not bother with the exhaust?
The slip joint connections on any exhaust should be sealed as well in my opinion.
You'll need a high temp sealer which can be hard to find.
Cam lam do a good one.
Posted: Mon Jan 21, 2013 8:41 pm
by ArmandTanzarian
How hot does the Cylinder / downpipe join get? Most sealers are only good for 250 degrees Centigrade and I'd have thought that burning exhaust gases were hotter than that.
Posted: Mon Jan 21, 2013 10:09 pm
by nelson pk
Hi
Yes the gases are hotter but the pipe or barrell does not get as hot as the gases. That's why when you get an EGT reading of 560 degrees celsius, your cylinder, head and exhaust is not melting because the metal is not that hot just the gas.
The sealer i use goes up to 232 degrees celsius and is more than adequate.
Hope this helps.
Posted: Tue Jan 22, 2013 1:22 pm
by Toddy
nelson pk wrote:byron wrote:Donnie wrote:I've always used a heat resistant silicone sealant with copper gasket so a bit belt and braces. Don't need to use a lot, just a smear on each side.
^all whs
+1
+2
Posted: Tue Jan 22, 2013 2:01 pm
by ArmandTanzarian
I've got a tube of blue Hylomar indoors. That's rated for 250 degrees so I guess that'll do.
Posted: Wed Jan 23, 2013 7:46 pm
by koomwah
I always use basic clear silicon for cylinder head (no gasket), base ally packer (no gasket) and exhaust flange. Also used for exhaust slip joints, not had a problem with it
