Page 1 of 3
Standard looking long range fuel tanks
Posted: Mon Jan 21, 2013 11:58 am
by watto66
Hello All ,
Apologies if this has been covered already on here .
I am thinking of going down the route of running a 25mm dellorto on my GT 186 kit without the airbox and using a remote filter ( marchald looks good ? ) and would like a standard looking larger fuel tank and i don't really want a stainless one . Any thoughts on who may stock a quality tank ? , i have looked at CAMLAM and Diablo Moto ( i cant see Diablo motos because their website is being updated ) also will i need a rear exit type fast flow tap due to the positioning of where the fuel tap fits ?.
Any info would be greatly appreciated.
Re: Standard looking long range fuel tanks
Posted: Mon Jan 21, 2013 12:09 pm
by ArmandTanzarian
There are some standard looking ones from the far east but the quality is hit and miss. I had two and they both leaked from where the thread for the tap is welded on. In fact that makes the quality miss and miss.
Posted: Mon Jan 21, 2013 12:14 pm
by bizzly
Will you still be using the tool box as a tool box ? If not, you could get it done like this...I know this is in stainless, but my other scoot has this done with the old metal tank and tool box.
Also, the rear exit fuel tap is better in my eyes, as the petrol pipe could rub against the engine mount on a normal down feed. I have the rear ones on both of mine for that reason.
Posted: Mon Jan 21, 2013 12:31 pm
by simonwwfc
Looks grand job
Posted: Mon Jan 21, 2013 4:04 pm
by joeswoonara
this is the standard Diablo tank .......probably not quite what your looking for but by far the best
Posted: Mon Jan 21, 2013 7:19 pm
by Timbo
Corrado on here is the man. http://www.justlambretta.com/
Posted: Tue Jan 22, 2013 10:18 am
by Ihateyoubutler
joeswoonara wrote:Image
I have a diablo tank which he made with a small toolbox in the front. Don't need a rear exit fuel tap for a ts1 but might make pipe routing easier.
Posted: Tue Jan 22, 2013 12:40 pm
by corrado
Timbo wrote:Corrado on here is the man. http://www.justlambretta.com/
I usually do these 12 litre ones in various guises. Right cut out, left cut out, twin cut outs, some that bolt in and some that use extended straps. At the minute I'm completely out of them until early March when the next batch arrives. They're around the £100 mark.
Posted: Tue Jan 22, 2013 2:46 pm
by twenty eight
this is my tank 18l fibreglass from beedspeed cut outs on both sides simple fit extra long tank straps and your tank rubbers,or this is a twin tank convertion i had done 13l keeps standard look can use any size carb both sides still got it
Posted: Tue Jan 22, 2013 9:47 pm
by rosscla
There's this one on fleabay
271130898458
