2 stroke oil to dry ??
Posted: Sun Jan 20, 2013 8:21 pm
by col68
Just had my sons piaggio nrg 50cc water cooled in a local bike shop in boston lincs . Had to have an engine rebuild because the crank bearing cage broke . Garage said oil used was to dry
he is using rock oil pp2 2 stroke through the injection pump. Engine had done 20,000 miles . Is this a good oil to use on this engine not tuned piaggio. new barrel fitted about a 1000 or so miles ago , engine revs to about 11,000 ? Engine had new crank bearing , seals , new con rod kit , piston and rings so is the oil too dry ?.Any help thanks col
Re: 2 stroke oil to dry ??
Posted: Sun Jan 20, 2013 10:00 pm
by twin
ring andy at PSN 01924 445 449,he will tell you,
not had that one oil to dry?
Posted: Sun Jan 20, 2013 10:42 pm
by Muppet
i think i wood look at the pump cus its more chance its gonna be to little oil; not dry oil,
muppet,
Posted: Mon Jan 21, 2013 10:48 am
by col68
Muppet wrote:i think i wood look at the pump cus its more chance its gonna be to little oil; not dry oil,
muppet,
I was thinking that to. Seals had were knackered was the first thing they told me . never herd of any oil being to dry . When i said should i put some more oil in as a premix (1 percent) said it would lean it up to much ? I had 9000 on that oil before . Could it just be that bearing had worn out ?
ta col
Posted: Mon Jan 21, 2013 11:06 am
by col68
twin wrote:ring andy at PSN 01924 445 449,he will tell you,
Thanks for psn number andy was very helpful :bigsm: . Sounds like we got over charged for work it would have been cheaper to have took bike to west yorkshire. :flaming: :flaming:
Posted: Tue Jan 22, 2013 6:32 pm
by twin
when some one says oil was to dry,and if you put more oil in it will lean it off,you got to get it out of there,
Posted: Sat Jan 26, 2013 3:19 pm
by shocky
col68 wrote:Just had my sons piaggio nrg 50cc water cooled in a local bike shop in boston lincs . Had to have an engine rebuild because the crank bearing cage broke . Garage said oil used was to dry
is he related to ray kemp ?
Posted: Sat Jan 26, 2013 3:51 pm
by col68
shocky wrote:col68 wrote:Just had my sons piaggio nrg 50cc water cooled in a local bike shop in boston lincs . Had to have an engine rebuild because the crank bearing cage broke . Garage said oil used was to dry
He could be distant relation
Posted: Thu Feb 14, 2013 9:16 pm
by col68
How about this then my son bike had to go back in to launchburys in boston on wednesday thinking that head was leaking . They say head not leaking but a wire broken to temp sensor on head make flash on head set top . But the spark plug is burnt to out making it stutter at about 9000 revs , after 500 miles in there words the oil is too dry make engine run hot and as burnt the plug out :wtf: :shocking: . Would this be a timing problem
what should the timing be set at on a piaggio nrg 50 lc so that I can get it checked . Thanks col
