Latest addition to Oiltek Tanks is the 13 Litre Tank, which allows the use of the toolbox. Made in England from 3mm Aluminium, the tank fastens into the frame like the long range Tank, with a "U" bracket and 10mm bolt where the Air Scoop was and two 8mm bolts at the rear.
Tank is £230 incl.VAT
