Ignition switch operation?
Posted: Fri Jan 18, 2013 1:19 pm
by eadmr04
The festoon parking/day light was not working on my GP. It's got an a/c electronic kit on and if I'm correct in thinking the festoon bulb should work when the switch is in the second position and turned off when you go onto main beam? I've tested the bulb which is ok and the earth side of the bulb holder is ok but I don't seem to be getting any voltage the other end which is the yellow wire from the ignition switch. I thought the switch was faulty so have bought another one but still the same. Rear light, brake, horn, speedo, high and low all work perfectly, it's just the festoon one which doesn't. Should there be voltage/power coming through the yellow wire from the ignition switch in one of the positions? I had an Indian switch but have now fitted a Casa one.
Re: Ignition switch operation?
Posted: Fri Jan 18, 2013 1:31 pm
by firekdp
Check that the switch purple (this is the feed into the switch for pilot lights) has power. If you've fitted an electronic loom, this will need to be connected to the browns.
Posted: Fri Jan 18, 2013 2:08 pm
by eadmr04
Cheers, will have a look tonight and post back :)
Posted: Fri Jan 18, 2013 3:44 pm
by firekdp
Sorry forgot this bit.
eadmr04 wrote:and if I'm correct in thinking the festoon bulb should work when the switch is in the second position and turned off when you go onto main beam?
With the Casa, the festoon will go off in position 3 (main lights). With the Indian it will be on in positions 2 & 3.
Posted: Fri Jan 18, 2013 6:05 pm
by eadmr04
Thanks for you help, looks like I had it all wired correctly and the ignition switch was ok........ bad connection on the terminals between the brown and purple :roll: all ok now. Cheers.
