Page 1 of 2
edge of piston going well below exhaust port at BDC
Posted: Fri Jan 18, 2013 10:25 am
by tonydevon
so in theory this isnt good surely, theres a lip that gases will hit and swirl around
is it really bad though?
brand new Mugello kit, and at BDC the edge of the piston is about 1.8-2mm lower than the bottom of the exhaust port
if its bad enough that it shouldnt be used, then whats the steps to sort it?
Re: edge of piston going well below exhaust port at BDC
Posted: Fri Jan 18, 2013 10:29 am
by tarmac tickler
and when piston is at top dead centre how far below the top of the barrel is it?
Posted: Fri Jan 18, 2013 10:48 am
by tonydevon
its below it, didnt measure exact amount, but squish appears to measure 1.3mm
time to go back through things I guess, cant beleive that the kits a wrongun, so I must have done something
Im using a base gasket but its a paper one, and beside if the squish is right then I dont want to be lowering the barrel anyway??
Posted: Fri Jan 18, 2013 11:28 am
by tonydevon
ok so panic over, just had a call from the shop that supplied it, apparantly they spoke with the supplier and Charlie someone?? they are aware of it but its not a problem
phew I can breathe.
MOD please feel free to delete thread if needed, save some space:)
Posted: Fri Jan 18, 2013 12:15 pm
by carlos fandango
Like Eden asked, if its a 60mm crank ? The piston will/should be 1mm lower at BDC, if the barrel is ported for a 58mm crank.
However the port (and trans ports) SHOULD be level at BDC if the crank and kit are as intended.
tonydevon wrote: they are aware of it but its not a problem
p
It will work fine , but it should be level, and if they are aware of it its a fault and should be rectified IMO.
Buying a kit off the shelf and a crank from some where else, with a case from one of three different countries , that all vary slightly, will always find discrepancies , but 1.8-2mm is quite a difference.
Posted: Fri Jan 18, 2013 12:20 pm
by tonydevon
as far as Im aware its a 58mm crank, its just the MEC GP replacement one, top end kit and crank, along with bearings seals gaskets etc all came from same place.
I wouldnt do it, but what would the effect be of that port being cut out and lowered so that the bottom of the port was level with the edge of the piston?? I like to learn
Posted: Fri Jan 18, 2013 12:29 pm
by carlos fandango
tonydevon wrote:as far as Im aware its a 58mm crank, its just the MEC GP replacement one, top end kit and crank, along with bearings seals gaskets etc all came from same place.
It will/should run fine and you probably wouldnt notice and difference if it was level.
But thats not the point really , its not difficult to work out where the bottom of the port should be with the barrel in your hand, gasket face to bottom of port should be 58mm or as near as damn itfor a 58mm crank .
If its wrong it wrong and should be corrected, but thats up to you ?
I was more concerned about the dealers comments, if they are aware of it why are they selling them ? BTW i doubt that Charlie (Edmonds, Google him
) would settle for it in one of his engines !
Posted: Fri Jan 18, 2013 12:31 pm
by WINTERMODEL150
Once the engines built make sure you pressure test it to make sure you don't have any air leaks,as this can be the route of most engine failures.
Dean
Posted: Fri Jan 18, 2013 12:37 pm
by tonydevon
ok thanks all, will pull it apart tonight and check it all again, take some photos and measurements
I had planned to get it tuned at a later date anyway by someone that actually knows what they are doing.
going to measure the squish again and make sure that Im doing that right, then look at everything and decide what way to go forward
Posted: Fri Jan 18, 2013 1:57 pm
by tonydevon
but is fixing it as simple as have the bottom of the port lowered?
from my basic understanding raising the top of the port affects the timing, but lowering the bottom of it should be ok??
its nikasil so I suppose that I have to factor in a replate once its altered.
