drt reed valve kit
roadrunnerian
hi has anyone fitted this kit or the worb5 kit, did they had to do much reworking of the inlet port or will they just fit straight on with no mods and with the standard carb thanks :?
GLscoot
Main scooter: Vespa GS150
Not that i know a lot about this. What engine are you using>
Gary
paddyfitz
Yup. DRT.
It's for a large frame Vespa.
You'll need to remove material from the case in order to give the reeds enough room to open.
I chose to split the cases to do it. Could be really messy if you didn't.
Installation moves the carb box slightly forward & up. Sounds weird, but everything fits.
You might need to make a gasket or 2.
It was a decently made product.
I can see someone running an autolube system having issue with it.
roadrunnerian
hi thanks for the replies its for a mk1 t5 non auto lube, with a standard carb with a suzuki polini conversion i find its not very quick off the mark very boggy low down.
    Users browsing this forum: No registered users and 64 guests
