Page 1 of 2
Gearing question
Posted: Wed Jan 16, 2013 2:55 pm
by psychedelicropcircle
I am moving from tv200 gearing to gp200 . The chain looked slightly loose on the front sprocket.....then I remembered I have a 46 tooth rear sprocket. Do I get a 47 tooth or would an 81 pitch chain do?
Re: Gearing question
Posted: Wed Jan 16, 2013 4:59 pm
Just checked the bible it's an 81 stretch I need :bouncyeng:
Posted: Thu Jan 17, 2013 7:42 am
by Toddy
You could always use the Push down type chain tensioner allows you to use a decent new chain rather than a used /stretched one
Posted: Thu Jan 17, 2013 8:40 am
by bizzly
Something like this...then use a new 82 link chain
Or this one
Posted: Thu Jan 17, 2013 9:27 am
by OAP
sprockets for GP 200 gearing are 47 / 18 with 82 chain!
Posted: Thu Jan 17, 2013 10:31 am
by Minority
OAP wrote:sprockets for GP 200 gearing are 47 / 18 with 82 chain!
Nice to have you back Ron, hope your fully recovered.
Posted: Thu Jan 17, 2013 11:02 am
by goldeneye
what motor and pipe is it for scott?
Posted: Thu Jan 17, 2013 6:43 pm
Aye jeff its for the avanti and one day itll have a mb clubby or RM clubby whichevers available first the barrel/ pistons away getting a reed valve matched etc to stop the spitback. the push doon fellas looking likely.
ron ill be in touch for a avanti gasket set.
Posted: Thu Jan 17, 2013 10:49 pm
by wack 63
Let us all know how you get on with the reed valve and any mods to piston.
Posted: Fri Jan 18, 2013 1:25 am
by goldeneye
try 19x46 with the GP 200 box, and 82 link chain, will give 4.8 ratio, if thats gannin in ya series yin, that should pull canny.
