timeing on a t5 malossi
Posted: Wed Jan 16, 2013 9:40 am
by soulboy
ive been told that i AVTO adjust the timing when i put the kit on now i dont have a strobe or anything like that so could someone please show me a pic/diagram as how much i need to move it and weather clockwise or anticlockwise would 2 base gaskits be a benifit ..cheers in advance
Re: timeing on a t5 malossi
Posted: Thu Jan 17, 2013 11:07 am
by cit205
You don't have to adjust the timing on the T5 malossi kit. I ran one for 15 years with no problems, the only thing i made sure i did is change the rings every 3000 or so. Just make sure it's upjetted right.
If you think you need to retard the timing a degree or two you can just turn the stator clockwise a mm or two.
You do need retard the timing a lot on PX200 malossi 210 kits and so on, maybe whoever told you was thinking of those.
I have still got some T5 172 kit instructions at home, and i'm pretty sure it tells you to leave the timing at 16 in them.
Posted: Thu Jan 17, 2013 11:22 am
by roadrunnerian
hi i ran mine at 16 degrees as standard and changed the jetting to 122 which you get with the kit.
Posted: Thu Jan 17, 2013 6:16 pm
by soulboy
thanks a lot fellas it as a 122 jet ..aint they fukin noisy with a cosa clutch as well
Posted: Thu Jan 17, 2013 6:44 pm
by ducksta
they all rattle dont panic
Posted: Thu Jan 17, 2013 7:03 pm
by roadrunnerian
never known any not to rattle just rev it harder m8
Posted: Thu Jan 17, 2013 7:36 pm
by soulboy
best advice ive ever had :baddevil:
Posted: Fri Jan 18, 2013 9:00 am
by cit205
There's a certain amount of piston slap on tickover with the 172, although you can't see it by eye the piston tapers down more than a lot of others , also the cosa clutches chatter like f*ck especially if using 1 or 2 tooth different from standard, it's just the gear meshing a bit sloppy. As above, it goes away when revved and everything runs fine
Posted: Fri Jan 18, 2013 9:02 pm
by wack 63
I always set them to 14 degrees BTDC.
http://beedspeed.com/html-pages/IgnitionTiming.htm .Not had one blow up yet :bigsm:
Posted: Mon Jan 21, 2013 6:46 pm
by soulboy
how much do i have to move it then wack
