gearbox endplate shim size advice
Posted: Mon Jan 14, 2013 10:44 pm
Hi, sorry for might seem a basic question, I have fitted new rear hub bearing and now that Im rebuilding the motor I have measured the clearance at the endplate as .35mm
I know that the advised range is .07 to .30mm
the shim in there is 2.3mm I reckon, will measure with metric tools tomoro at work, 90 thou.
anyway
do I aim for a clearance in the middle of the ranges, ie maybe 0.15? and thus buy a 2.5mm shim,or if stuck between sizes is there any sensible reasoning or modern thoughts on which end of the tolerance I shoulld aim for.
thanks
anyway
thanks
