Mallossi 210 Advice
Posted: Mon Jan 14, 2013 10:58 am
by steeleyscoot
Can someone tell what's the real performance uplift I can expect by fitting a Mallossi 210 cylinder kit, upjetting the standard carb to suit and fitting the SIP road/race box to a standard P2 lump..?
In other words no fettling of the engine cases to suit etc...
What can I expect over the performance from the standard stock engine...?
Re: Mallossi 210 Advice
Posted: Mon Jan 14, 2013 11:17 am
by lockman69
Gps..65....70Mph at a push....depends if your a fatty or a thinny.
Posted: Mon Jan 14, 2013 11:28 am
by steeleyscoot
Thanks for that - would I be able to keep the autolube system.....?
Posted: Mon Jan 14, 2013 3:52 pm
by dopeshots
With the std carb yes u can keep the autolube.
Posted: Mon Jan 14, 2013 5:09 pm
by lockman69
You will need to re-set your timing, opinions will vary but I ran mind at 16' BTDC with no issues or pinking.
Posted: Tue Jan 15, 2013 8:42 pm
by andy66
lockman69 wrote:Gps..65....70Mph at a push....depends if your a fatty or a thinny.
its a lot of money to spend if your just going to bolt it on.........gets there alot quicker,plenty of torque......but
ive got a bog standard p2 with a sip pipe and i go 2 up everywhere but when its just me i get near those speeds.
only my opinion but if i was to put one on id have a bit more work done to get the full potential out of it.
Posted: Sat Jan 19, 2013 6:54 pm
by Juan
You'd be far better off going with the Polini over the Malossi.
Polini are, or perhaps even have by now, introducing their 210 alloy hit complete with cylinderhead this year.
Malossi makes it's power far too far up the rev range and is just a plain pain in the arse unless everything else is just so.
Posted: Sat Jan 19, 2013 10:32 pm
by dopeshots
I have a fully ported Malosi 210, 30mm carb, reed vale, race crank, jl exhaust that puts out 23bhp. It will pull std p2 gear no problem and will sit at 75 all day long. I love the engine as it pulls brilliantly. If you can afford to do it properly you will love. Not brilliant on fuel but hey that's the trade off.
Hope that helps....
Russ :fb:
