Page 1 of 2
indian fork spring stops
Posted: Sun Jan 13, 2013 10:55 pm
by marktheskin
anyone now if my 1981 SIL Vijai super has steel fork spring tops or the nylon type? need to know because i dont really wanna strip down my forks to fit dampers
thanks alot
Re: indian fork spring stops
Posted: Sun Jan 13, 2013 11:11 pm
by Andy Pickering
Mine had nylon..if your welding on top brackets for dampers I would remove springs just to be on the safe side plus check their condition if it's a fresh import from Delhi as their roads are pretty lumpy to say the least :grin: mine had a broken spring on inspection.
Posted: Sun Jan 13, 2013 11:51 pm
by paulmgreen
Yes.... What Andy says!
Strip them down! Doesn't take too long. A job worth doing ....
Posted: Mon Jan 14, 2013 6:04 pm
by marktheskin
well i tried to strip my down today and using the trusty stickys book got pissed off with it because i didnt get anywhere after and hour of trying to lever out the bump stops(that and it was freezing cold with snow) so maybe another attempt when im not pissed off with it i think :d
Posted: Mon Jan 14, 2013 7:15 pm
by Andy Pickering
Do the stops have bent over strips of metal that hold them In place? If they do bend them over for ease of removal.
Posted: Mon Jan 14, 2013 7:31 pm
by marktheskin
yes they do! and thankyou they should just like drop out then shouldnt they?
Posted: Mon Jan 14, 2013 7:39 pm
by Andy Pickering
From memory mine did take a fair bit of prizing out tbh, they had been in there neah on 30 years :grin:
Posted: Mon Jan 14, 2013 7:41 pm
by marktheskin
well apparently the whole scoot was rebuilt before it came into my possession. however, if the engine rebuild was anything to go buy they will be a tw*t haha
Posted: Mon Jan 14, 2013 8:33 pm
by Andy Pickering
Check they ain't bolted as well lol..you never know.
Posted: Tue Jan 15, 2013 2:38 pm
by simonwwfc
we had a mare getting the stops out when i fitted disc conversion nightmare but i replaced fork links and fork rods inside springs as well much better now
