Hi i have a slight problem with me mk1 T5 headlight as when i put on the indicators with the headlight the flashers stop working on the back and the headlight flashes :wtf:
when i switch the headlight off the flashers work normally, they also work fine with the sidelight. this only happens with the headlight.
i did think that maybe i had trapped wire when i did headset up but it still does it with headset off
has anyone got a clue what might be wrong
cheers steve
T5 electrical problem
- smoore-gt225
- registered user
- Main scooter: lambretta GT200
- Contact:
check the wire from the frame into the toolbox has not been earthed out mine was and i had exactly the same problems
