T5 electrical problem
Posted: Sat Jan 12, 2013 8:44 pm
by smoore-gt225
Hi i have a slight problem with me mk1 T5 headlight as when i put on the indicators with the headlight the flashers stop working on the back and the headlight flashes :wtf:
when i switch the headlight off the flashers work normally, they also work fine with the sidelight. this only happens with the headlight.
i did think that maybe i had trapped wire when i did headset up but it still does it with headset off
has anyone got a clue what might be wrong
cheers steve
Re: T5 electrical problem
Posted: Sat Jan 12, 2013 10:23 pm
by ducksta
check the wire from the frame into the toolbox has not been earthed out mine was and i had exactly the same problems
Posted: Mon Jan 14, 2013 10:11 am
by soulboy
as above
