Page 1 of 2
jetting for t5
Posted: Sat Jan 12, 2013 8:43 pm
by roadrunnerian
i have a polini suzuki 171 conversion with a standard carb i was thinking of fitting a 185 air corrector has anyone else fitted one and what tube did they fit a bes 5 ? thanks ian :biggrin:
Re: jetting for t5
Posted: Sun Jan 13, 2013 3:21 pm
by goldeneye
i had a 190 air corrector (top jet on the stack) on a malossi 210, worked ok , but subsequent 210"s ive done, ive drilled the filter , and used the standard 160. if using a T5 carb, the air corrector is shorter, and a P2 one will not fit with the larger T5 filter. why not try a P200 carb, its slightly taller and will give you more options jetting wise. from memory, is the T5 one a 120?
Re: jetting for t5
Posted: Sun Jan 13, 2013 9:41 pm
by roadrunnerian
hi goldeneye you are right about the standard size 120 i have the polini air induction kit on might just try the 185 thanks for the reply m8
Re: jetting for t5
Posted: Sun Jan 13, 2013 10:36 pm
by ducksta
i have sameset up as roadrunnerian but standard carb sat on top of a dr reed valve works well
Re: jetting for t5
Posted: Mon Jan 14, 2013 8:33 pm
by roadrunnerian
ducksta m8 was it a big job fitting your reed valve ?
Re: jetting for t5
Posted: Mon Jan 14, 2013 10:27 pm
by ducksta
bolted streight on no mods thought your ears might prick up lol no splash back with the induction kit etc
Re: jetting for t5
Posted: Tue Jan 15, 2013 12:39 am
by gaz_powell
any pictures or details of the reed valve block
gaz
Re: jetting for t5
Posted: Tue Jan 15, 2013 11:31 am
by roadrunnerian
hi ducksta any details m8 sounds very interesting thanks ian
Re: jetting for t5
Posted: Tue Jan 15, 2013 9:08 pm
by roadrunnerian
hi ducksta just read the info off the sip site, how much mod work did you do to the casings m8
Re: jetting for t5
Posted: Tue Jan 15, 2013 11:20 pm
by ducksta
martin at chissy did it dont think they was much to do it only lost half a brake horse but runs spot on and starts first time and no bloody splash back on the induction kit
